It is currently Sat Oct 31, 2026 9:29 am
PostPosted: Wed Sep 30, 2015 6:48 pm
Pretty sure these will go as telco. But do I need to remove the metal bracket on the connectors? Thanks guys
PostPosted: Thu Oct 01, 2015 12:50 pm
Definitely telco and no. Don't remove the bracket unless you want it froe steam punk art. :)
PostPosted: Sun Mar 27, 2016 10:59 am
I have removed the bracket from all of my boards, are you saying I decreased the board??
PostPosted: Sun Mar 27, 2016 12:10 pm
The standard brackets do not need to be removed.
You didn't lower the board Grade but you did decrease the overall weight.
PostPosted: Sun Mar 27, 2016 12:59 pm
Thank you for your quick response. I will keep that in mind for future reference
PostPosted: Thu Apr 21, 2016 7:12 pm
Only time I would remove brackets is if you are shipping these type of boards in and need room in the box you are shipping in for other things, or if you are trying to get the gross weight of the box down to avoid getting dinged with a heavy package surcharge by the shipping company.
