It is currently Thu Oct 29, 2026 9:11 pm
 Post subject: Old ibm hard drive
PostPosted: Mon Feb 12, 2018 10:18 pm
I feel like somebody would want this. It has an old copyright on it. I already took most of it apart. But i have two. Never saw one like this.
 Post subject: Re: Old ibm hard drive
PostPosted: Tue Feb 13, 2018 12:28 am
It’s a 1993 (controller board date) SCSI hard drive. Depending on the size of you can test it and run a disk scan; a drive with no missing tracks and no dead sectors will run $25-$50 at the low end.
PostPosted: Tue Feb 13, 2018 8:00 am
well I guess it is just scrap then since I took it apart and it has a screw into the the disc area.
What would the boards go as? there are a few of them inside and it is not the easiest thing to get apart.
PostPosted: Tue Feb 13, 2018 5:13 pm
The primary controller board will get hard drive controller
Most of the rest should be peripheral
The brown wire goes as mix dnwite but you can easily pop the ic chips off for ic rate on those.
