It is currently Fri Oct 30, 2026 1:46 am
PostPosted: Fri Aug 29, 2014 9:50 am
Does boardsort want the metel ends on gold finger cards left or can they be removed?
PostPosted: Fri Aug 29, 2014 2:33 pm
You can leave it on. Make sure you remove the aluminum heat sinks from the chips though.
PostPosted: Sat Aug 30, 2014 1:30 pm
I remove the brackets from any fingered cards that I have unless the brackets are riveted on. My reasoning for this is that with the brackets removed, there's more space available in the container I'm packing the cards in for additional cards.
PostPosted: Sun Sep 07, 2014 10:02 am
thanks I know I lose weight if I remove the metal but it makes it easier to pack.
