It is currently Fri Oct 30, 2026 10:29 pm
 Post subject: tv capacitors
PostPosted: Tue Sep 30, 2014 9:42 pm
Do you buy tv capacitors? If so what do you pay per lb
 Post subject: Re: tv capacitors
PostPosted: Wed Oct 01, 2014 11:09 am
If you are referring to the large lead/glass picture tube, then the answer is 'no'. There is significant cost in melting down the tube to separate the lead and the glass. The only part of a CRT that boardsort will take is the circuit board, which is bought as low grade.
PostPosted: Wed Oct 01, 2014 9:53 pm
Okay thanks
