It is currently Fri Oct 30, 2026 12:50 pm
 Post subject: Cd/dvd question
PostPosted: Mon Oct 02, 2017 11:14 am
If I remove boards from cd/dvd what value does the unit have with no board ?i see a cd/dvd board is $3 a pound and a cd/dvd is .15 a pound
 Post subject: Re: Cd/dvd question
PostPosted: Mon Oct 02, 2017 2:38 pm
To boardsort that’s about it. The laser chip inside behind the laser array will go as IC, green/brown fibre (less likely), or green DLP (least likely) depending on design.
Outside of boardsort taking the board and chip the dissection scrap value is between 75c and $2 in ideal conditions. The older the drive the higher the value in metals.
