It is currently Sun Nov 01, 2026 11:06 pm
PostPosted: Thu Dec 04, 2014 10:03 pm
I have some boards which I am not sure if they are peripheral or mid grade. I would like to know the difference so I can tell them apart. Can somebody please tell me the differences between the two so I can accurately grade?
PostPosted: Fri Dec 05, 2014 12:35 pm
Peripheral boards contain some IC chips and very few power components such as resistors, capacitors, and transformers. The board needs to be green on both sides, with the exception of a floppy drive controller board, which is graded as peripheral due to the presence of gold pins on the back.
Mid grade boards are green on both sides and contain mostly capacitors, resistors, and transformers, and very few IC chips.
PostPosted: Fri Dec 05, 2014 3:41 pm
Thank you kgryczan, I think I'll be able to tell most boards apart now.
