PostPosted: Fri Jun 20, 2025 6:18 pm
Tore down my late wife's all in one from the late 90s what is this guy abd what would it be classed as?
File comment: Gold legged all the way through the board clear top with visible gold in the chip
PostPosted: Mon Jun 23, 2025 6:21 pm
I just saw that exact board. Tossed it in low peri. I may be wrong....
PostPosted: Tue Jun 24, 2025 4:12 pm
Most likely High Per/Low Per. If you remove the IC, I believe it can go to classes from IC, to between DLP ceramic. I doubt it would go any higher to Pent/AMD ceramic.
I want to say it would class Green/Brown fiber no metal, imo
PostPosted: Fri Jul 04, 2025 8:09 pm
I posted a couple different variations of this type of board before the high low split in the peripheral grade. Lost graded as peripheral then so I'd lean high peripheral now.
viewtopic.php?f=4&t=19300&p=34875#p34875
