It is currently Mon May 25, 2026 11:39 am
PostPosted: Thu May 14, 2026 8:52 pm
Took apart a couple of pretty cheap laptops that had these boards.
1: I assume would be classified as a laptop motherboard, but do I remove the chip?
2: peripheral low grade?
3, 5, 6: Think these might just be mid grade, the pins don’t appear to be gold.
4: high peripheral?
PostPosted: Thu May 14, 2026 9:35 pm
1 laptop board
2 Peripheral High Grade
3-5-6 i have sent in as low Peripheral
4 Peripheral High Grade
PostPosted: Fri May 15, 2026 3:54 am
I agree with austin86.
PostPosted: Fri May 15, 2026 7:04 am
Chip stays it's soldered on (only remove socketed ones). Remove the steel from the laptop mobo, I usually push the on the standoffs (where the fan/heatsink was screwed to) to break the adhesive
I've always done 3,5,6 as midgrade, but that's a habit from before the peripheral split, is there really enough there to bump up?
Rest I agree with.
PostPosted: Fri May 15, 2026 9:10 am
I sent them in as low peripheral more then a few times.
PostPosted: Sat May 16, 2026 9:44 am
Thanks for posting these OP. I have a few of these I was on the fence with how to grade. Now I don't have to waste everyone's time and repost mine.
I always have to re-remember visible gold = peripheral (as a general rule as there is always exceptions).
