It is currently Tue Jul 28, 2026 12:02 am
PostPosted: Fri Jul 24, 2026 7:56 pm
Hello, can someone please tell me how BoardSort would grade these 4 boards? They all came out of devices that used telecommunication.
PostPosted: Fri Jul 24, 2026 8:36 pm
4 midgrade
3 probably good for high telco
2 sockets look metal but not sure depending on the weight of those either high peripheral or low telco
1 probably good for low telco
I will note, most of the pictures are not great, everything seems yellow (probably your indoor lighting), so all visible pins look yellow, meaning visually there's no way to tell if any are gold. Couple are blurry and there's some harsh glare. I don't think it's bad enough to affect the grade but it is something to be mindful of when taking pictures. Make sure the color is fairly accurate and everything is in focus. The layout and framing is great, getting as much board in each picture as possible without cutting anything out that isn't visible in another.
PostPosted: Mon Jul 27, 2026 11:20 am
Thank you!
