It is currently Wed Sep 30, 2026 7:13 pm
PostPosted: Sat Sep 26, 2026 10:32 pm
Can anyone one help me with the grade of this board? I think its high grade telecom but not totally sure and do I need to remove the SFP cages? I tried removing the cages on a few smaller boards but it take the connectors with them. Thanks!
PostPosted: Sun Sep 27, 2026 5:12 pm
I'm not the best to be commenting but..., I've always understood it that if it's steel and can be removed with fair amount of ease, then it should be removed.
but
I'd want to know from someone more knowledgeable on this one because if I can stop doing that to some of the boards, I'd be really pleased!!!
PostPosted: Mon Sep 28, 2026 12:02 pm
Are they steel? If so, definitely try to get as much off as you can, unfortunately I'm not familiar with these so I'm not sure the best way to go about that.
PostPosted: Tue Sep 29, 2026 7:06 pm
How about a side view looking right into the ports.
PostPosted: Wed Sep 30, 2026 7:56 am
I’m not sure it would by telco because it looks like a copper based board. I personally would leave the metal on and submit as high peripheral. I will add though, I get everything free so I am more concerned with saving some time when the payout is not significantly affected.
