It is currently Wed Nov 04, 2026 12:07 am
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
PostPosted: Mon Oct 05, 2020 6:39 pm
BTO?
PostPosted: Tue Oct 06, 2020 10:52 am
Honestly, I have no idea what the value of those units are. Looks like a lot of work would go into recovering the values unless there was an outright buyer for them, which unfortunately I do not have, at least at a price point that would work for all 3 of us.
So I would have to pass on that item. That is not to say there is not value, but I just do not see the opportunity for us to realize it.
Sorry!
PostPosted: Tue Oct 06, 2020 1:10 pm
Sorry. Chris has come back and said a flat out no as is.
They’re too difficult to break down for recovery.
Which leave me only one suggestion for you.
If you are still unwilling to let it go (I understand) there is a method I know will work most of the time. But it’s a long process.
Plain the cases horizontally. Board half and top half.
Turn them upside down
Press, punch, or drill a single hole through the centre of the lower case.
Now we heat it via convection.
Pizza ovens (stone/brick) work best or open fire kilns. But high end ovens work well too.
For stone etc just slide them in upside down and fire it up. Keep The the oxygen/vent door as open as it goes to keep the temp low.
For a house oven. Pre heat the oven to 200•
Once there crack the door to the opening and then set the temperature down.
If you have a keep warm setting use that (95•-125•). If not set it to 100•.
Place a sheet of aluminium in the lowest rack. Place the cases upside down on the highest rack.
Wait.
Make sure you have plenty of ventilation.
PostPosted: Tue Oct 06, 2020 1:11 pm
BTO=Build to Order.
PostPosted: Tue Oct 06, 2020 3:03 pm
thank you both for the reply, 340lbs of scrap steel it is
