It is currently Tue Oct 27, 2026 12:27 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Odds and ends
PostPosted: Sun Jan 07, 2018 1:22 am
Silver legs and magnetic legs in their own two piles. Plated legs with the heatsink (plated copper/brass)
Silver your looking at $12 or so per imperial ounce.
Raw refined Nickel is currently in the $20 range so you can expect $4-$8 per pound for your pins depending on many factors
Plated brass is $2-$4 and plated copper is $2-$4.50 nationally, per lb.
Divide all by 16 for per ounce price. Most places that buy sub-pound (other than gold or higher value materials) usually require a 2 ounce minimum. That’s where the industry standard scale company accuteck scales start at.
PostPosted: Sun Jan 07, 2018 6:32 pm
Alright so pulled this off the back. The leg still attached isn't magnetic. Do I keep this intact or still cut the leg and what does this go as?
Sorry it'll click for me eventually :-)
PostPosted: Sun Jan 07, 2018 7:49 pm
Corners give away that it’s silver plated. Also looks like the unit is still attached on the flip side. Cut the leg of and trim any of the back that extends beyond the unit.
The leg and sink trimmings will go as silver plated brass/copper, the remaining component is usually taken as cbm or heavy silver breakage. Similar in price.
PostPosted: Sun Jan 07, 2018 7:55 pm
This was the back
PostPosted: Sun Jan 07, 2018 7:57 pm
Is "the unit" the white thing?
PostPosted: Sun Jan 07, 2018 8:18 pm
Ohkay, I see. You broke the case apart. Lol.
Further than I go. So yes in this case the white thing.
PostPosted: Sun Jan 07, 2018 8:34 pm
I initially tried to just clip the corners but the whole sink started to pull away from the ceramic so I figured heck why not lol
PostPosted: Sun Jan 07, 2018 11:10 pm
These all look a little different - still clip in the same spot and classify the same?
PostPosted: Mon Jan 08, 2018 12:30 am
Hey, if you have a method have at it. Yes clip the same spots.
It’s simply a packaging design. Theoretically you can put anything you want in to. Resistors, inducers, inductors, transformers, fuses,
A 4004 at its lowest usefulness only needs 12 pins. So theoretically you could even package up a cpu in one of those designs.
PostPosted: Tue Jan 09, 2018 9:26 pm
Do these black things count as IC chips?
Those squarish silver looking things worth keeping?
