It is currently Sat Nov 07, 2026 2:11 pm
 Post subject: What are these?
PostPosted: Fri May 22, 2015 4:16 pm
Five different boards pulled out from same machine. What are these? Thank you!
 Post subject: Re: What are these?
PostPosted: Fri May 22, 2015 4:32 pm
My guess would be telco as is.
If you remove the socketed ics You'll get peripheral.
PostPosted: Fri May 22, 2015 7:52 pm
not sure if the chip population is enough to get telecom grade... if not, they may give you one of the higher motherboard grades.... if you take the ic chips off, you will definitely get lowered to peripheral though.
