It is currently Sat Nov 07, 2026 2:24 pm
 Post subject: Classification
PostPosted: Sat Jul 11, 2015 8:14 pm
What would these boards be classified as
 Post subject: Re: Classification
PostPosted: Sat Jul 11, 2015 8:26 pm
The first two would probably be telco.
Third one is questionable .
Forth (bottom ) is small socket since the cpu is hard soldered.
I can't tell from the photo but if the spreader is removable remove it from the second one should get a bump up a grade for you.
I suggest sending the two Bottom pictures by email for a definitive answer from Boardsort and let us know.
PostPosted: Mon Jul 13, 2015 2:36 pm
That third one is more in line with a small socket motherboard. The metal on the right side should be removed if possible.
