It is currently Sat Nov 07, 2026 2:24 pm
 Post subject: Is this a slot processor
PostPosted: Sun Jul 19, 2015 8:22 pm
Slot processor ??
PostPosted: Sun Jul 19, 2015 9:18 pm
That would go in green fiber with metal processor
PostPosted: Sun Jul 19, 2015 9:52 pm
That is the processor that came off the board that you said is a slot processor large socket motherboard
PostPosted: Mon Jul 20, 2015 2:07 am
Keep in mind that it doesn't have gold fingers like a slot processor. by missing those elements basically is lacking the same volume of precious metals than the standard slot processor would have in it.
PostPosted: Mon Jul 20, 2015 3:38 am
Ohkay the technical nonsense explanation
The term slot processor is misleading.
As far as Boardsort is concerned for recycling it gets the green fiber with metal category because it has pins instead of wedges or fingers
The board is still slot since those /pins/ in exact parallel rows fit into "slot b9" sockets/slots/jacks.
The pins on the cpu card are gold plated steel. The pin-socket receptors are gold milled nickle.
There's as much gold in those /whatever/ ports on the board as any other slot processor boards. I posted pictures of very similar b9 boards a few weeks back.
Unless Boardsort says otherwise you're safe going that route.
Slot technology is not an industry standardised methodology.
Which is funny if your into tech history. Trying to figure out why a power switch goes as telco but a communication hub board is midgrade.
Eventually you just get the hang of it through trial and error and my first or second sale to Boardsort got me a harsh but extremely motivational email for Being off in categories.
Read. Ask questions. And make mistakes. We all do that here.
PostPosted: Tue Jul 21, 2015 12:50 am
I have sent those in many times and have gotten telecom grade for those every time. the key is to make sure all Aluminum heat sinks are removed if they come with them (which you have done).
