It is currently Sat Nov 07, 2026 2:24 pm
 Post subject: help please
PostPosted: Wed Aug 12, 2015 3:18 pm
I pulled these out of a tv, are these solid gold or plated? Scratched them and all I see is gold. They are 23 grams each, 1"×1" square and about 1/8" thick. They each were on a copper heat sink. Any help is appreciated!
 Post subject: Re: help please
PostPosted: Wed Aug 12, 2015 3:26 pm
Low grade for board sort. Locally toss them in your copper barring material cbm or switches/copper cable ends if the have that class.
PostPosted: Wed Aug 12, 2015 3:34 pm
They aren't copper.....
PostPosted: Wed Aug 12, 2015 3:39 pm
Brass?
PostPosted: Wed Aug 12, 2015 3:58 pm
The heat sink there usually falls into copper aluminium radiator.
The switches I'm just basing on what the 3 yards i use class them as. Yes they're probably brass. One looks to be silver plated.
One yard i use has a class for power ends (#2 brass\silver or nickel plated #3 brass) and take all switches in that category as well 78c/lb on Monday
The other two don't sort ends out and take them as cbm/open transformers (switches cable ends and power supply boards and non-sealed transformers)
. 56c /lb on Monday.
Different yards take different things... differently. ;) ask them is my best advice but you're never wrong tossing in switches with cbm and/or motors or transformers if you only have a few.
