It is currently Sat Nov 07, 2026 2:55 pm
PostPosted: Fri Aug 28, 2015 8:47 am
In pic 1, should I separate the gold chip or send in whole board?
This is a Fiber optic laser board with laser under the cover
Pic 2 & 3 What would these grade?
Thanks
PostPosted: Sun Aug 30, 2015 12:19 am
Anyone??
PostPosted: Sun Aug 30, 2015 10:01 am
Top is a gold cap board. Unless it's in a socket getting the square chips off is a waste of time. Square gold caps are /almost always/ bga. Meaning little balls of gold plated AgAl2
Balls: no pins. If you remove the cpu you'll get a high grade ceramic rate most often not a gold cap rate. the fumes cause many problems to your health. It's not worth the risks for the extra 2-3 dollars. (And bs staff will tell you I'm notorious for stripping boards... there is a cutoff point price vs health)
Other two are peripheral
