It is currently Sat Sep 26, 2026 4:09 am
 Post subject: Quick question
PostPosted: Fri Oct 16, 2015 9:06 am
These are mid grade, right? And do the cords need to be cut off?
 Post subject: Re: Quick question
PostPosted: Fri Oct 16, 2015 11:53 am
Mid grade. Yes.
Id remove the wires since they're worth more.
Should probably remove the aluminium too. You'd be better off selling the whole board as is locally for aluminium breakage (old aluminium)
PostPosted: Fri Oct 16, 2015 2:07 pm
What if I were to say that I had like 10 Gaylord boxes of them?
PostPosted: Fri Oct 16, 2015 2:50 pm
That's alot of aluminium. :)
No wires and sinks are fine at that point.
My first suggestion is call local large recyclers and see if any of them take aluminium breakage or "old aluminium ". Then bring a sample in. Assuming those sinks are spun aluminium; you have a large population of aluminium capacitors there as well. My yard here pays al#3
If you go with boardsort The easiest cheapest way other than trucking it in yourself would be fedex freight or if east of the Mississippi try an ltl load from old dominion or rhole. Their prices tend to be fair.
PostPosted: Sun Oct 18, 2015 8:19 am
I dont know if this is allowable but I can beat FEDEX freight all day long unless you have a special arrangement with them.
PostPosted: Sun Oct 18, 2015 2:47 pm
Hey if you're an oo willing to haul ltl by all means please post.
Although the business side threads are a more appropriate location for such info.
Thankyou!
PostPosted: Mon Oct 19, 2015 7:02 am
I have posted there just wanted to comment. No disrespect intended
PostPosted: Mon Oct 19, 2015 8:22 am
None perceived. thanks for the help!
