It is currently Fri Sep 25, 2026 1:24 am
PostPosted: Fri Oct 23, 2015 11:26 pm
If you remove the metal from metal socket server boards, they would be bought as small socket server boards correct?
PostPosted: Sat Oct 24, 2015 12:33 am
you could try, but I'm fairly certain they will realize that the leftover black (and most likely broken) socket will indicate it used to be a metal socket MB... As opposed to the normal off-white color of all other small socket MB's.
PostPosted: Sat Oct 24, 2015 10:43 am
The metal socket boards go as such because of the land grid array sockets (lga) removing the socket metal catch lowers weight... but doesn't change rate. It's the lack of pins, not the metal that really decides a msm.
