It is currently Sat Nov 07, 2026 10:40 pm
 Post subject: Please ID
PostPosted: Tue Apr 30, 2019 11:50 am
I will attach a photos of the front and back. Multiple questions. This board came from a very old computer i stripped apart where it was a monitor and tower all in one. My guess would be that this would be categorized as a large socket motherboard, just like a laptop board.
Which pile should i add this board to and should i remove the 2 larger sized IC chips and trim the gold fingers?
 Post subject: Re: Please ID
PostPosted: Wed May 01, 2019 2:36 am
macs predating the ‘Lux’ version, and most // series are small socket green motherboards.
PostPosted: Wed May 01, 2019 7:05 am
It will still go into the green small socket category if i trim the gold fingers and take off the IC chips, correct?
PostPosted: Wed May 01, 2019 11:11 am
PostPosted: Wed May 01, 2019 4:17 pm
No. That helps push the otherwise peripheral board over the edge.
PostPosted: Thu May 02, 2019 8:25 am
Thank you! I will throw it, as is, into my green small socket bin
