It is currently Fri Nov 06, 2026 9:27 pm
PostPosted: Mon Jan 14, 2019 12:47 am
what do 586 cpu's grade as?
PostPosted: Mon Jan 14, 2019 1:17 am
Depends on both the manufacturer and the format.
Most pinned ceramic 586 CPUs will be 486 with a gold cap inside the pins will get Motorola/foreign or ibm/via gold cap rates. Depending on size. Smaller CPUs go as 486, the larger as gold cap
others without the cap get pentium Mac ceramic
However flip chip ceramics (with leads on the edges, not pins) will get pentium Mac ceramic if the Leads are gold, IC rate if nickel or silver.
The modern implementation of the AM80586 and AM80E586 are IC rate.
