It is currently Sat Nov 07, 2026 5:22 am
 Post subject: Some boards to check
PostPosted: Fri Jan 25, 2019 8:47 pm
Some more boards to identify and I have a couple of ? As well when you send in pins I know they have to be check and I do keep my stuff separated in water bottles and med bots .when they check k them does it show the gold percentage and other materials percentage ? The reason I am asking is because I am like anyone else wanting the most out of the e wastes they can .I keep track of where my materials come from so I learn what to get and not.the other things I was wondering is like processors that because they are not exact weights .I weigh my stuff on a meat scale tells the weight and how much I would get for one chip.is the payout by rounded lbs or paid out like a meat scale like 7.35 lbs ?
 Post subject: Re: Some boards to check
PostPosted: Sat Jan 26, 2019 2:06 am
Green fibre with metal
That’s a drop in power pc processor board
Gold finger card
Peripheral
You’ve got the right method. Everything directly on the list will give you individual category line items when you fill out the quote form telling you both what each category is worth and an order total.
Pins... are based on the value of the entire makeup of the pins.
XRF scanning tells the operator the (nearly) exact elemental makeup of an item. See the image. Boardsort will test the pins, then decide the weight out based on element readings. The payment is based on the values of the included materials in/on the pins.
In fantasy macro scale, say you sent them a single 1 Troy pound pin. That pin was 10% gold and 89% nickel and many tenths of a percent of other elements. Your payout would be 1/10 Troy pound gold and 9/10 Troy pound nickel.
$114 in gold and $3.99 in nickel
The gold rate from boardsort tends to be around .92 of commodity in most of the pins I’ve had quoted. Based on my having had a working XRF scanner for a while.
In reality you’ll never have a Troy pound pin and my materials example is just an example. But it should help you understand how it works.
PostPosted: Sat Jan 26, 2019 5:58 am
...payout is based on standard pounds and ounces
