It is currently Sat Nov 07, 2026 10:17 pm
 Post subject: What the heck?
PostPosted: Fri Feb 15, 2019 10:22 pm
Hi,
Hopefully someone can tell me what this is? Mounted to an HP Viridia Telemetry Mainframe card - sealed card (copper braid). Looks and feels like metal - but could be ceramic? Brittle - can be chipped easily. Hoping it's some kind of exotic metal Tungsten or Tantalum heat sink. Non magnetic - mounted in board with metal bracket that is.
 Post subject: Re: What the heck?
PostPosted: Sat Feb 16, 2019 3:37 pm
Well, step one, don’t break it any further.
My first guess was tungsten hematite. A common metallic ceramic; used in heat spreaders and “goth” jewellery.
But that’s highly magnetic.
So my second choice? Boron carbide. Boron is a diamagnetic material that becomes magnetically neutral (nearly) when alloyed at near 50/50 with carbon. It’s hard, space wise, but brittle. Items are made by dumping a dry powder into a mould and compressing it under many many tons of pressure. It’s difficult to break initially but once damaged can be crumbled easily.
C5B is a common choice in high leakage electrical environments.
As is it’s non toxic. But do NOT get it wet. You quickly get Boron Hydroxide. A relativly toxic gas. Which is why boratic acid laundry soap has sulphur in it. Which stabilises the reaction to non-toxic gases.
Most large steel yards will take it at steel rates.
C5B is a logical choice given the copper braiding around the case.
PostPosted: Sun Feb 17, 2019 11:24 am
Thanks Lostinlowdos. I guess my plans to vape with it are ill advised. By the way, you're much smarter than Google lol
PostPosted: Sun Feb 17, 2019 4:49 pm
You’re welcome. And I think it’s actually I’m dumber than google.
My previous signature was “ask me... I blow myself up so you don’t have to”.
It’s not a common metal in that form. Though that usage is a go to for ‘we give up’ board design. There’s a lot of it in early 8-bit computers. Was one source of landfill fires in the mid to late 90s. You also find it in, like yours, high end rack equipment. But most of this exists in 70s era AV equipment like tuners and Betamax players.
And microwave ovens as Boron Beryllium alloys.
I found out about it when it made me sick. Real sick! Lol. Keep it dry.
PostPosted: Mon Feb 18, 2019 4:36 pm
Will treat it like my powder - thanks again
