It is currently Sat Nov 07, 2026 10:17 pm
 Post subject: Few boards to ID
PostPosted: Sun Feb 17, 2019 4:35 am
1 Both connectors have gold pins I'm sure its peripheral just making sure , 2 This came out of a wireless printer should this be small socket mobo ? 3 Is it OK to take off the heat sinks on metal top CPU to clear no metal. Not sure if they mind or not. Thanks
The greatest threat to our planet is the belief that someone else will save it.
 Post subject: Re: Few boards to ID
PostPosted: Sun Feb 17, 2019 6:23 pm
3) yep. Now no metal
2) peripheral
1) peripheral
PostPosted: Sun Feb 17, 2019 7:19 pm
Ok thanks a lot.
PostPosted: Sun Feb 17, 2019 11:32 pm
On the CPUs with a metal top:
I weighed some before removing the tops and then again after. Based on the payout rates at the time I found that I would have made more if I had left the metal on the CPUs.
Just something to consider, especially since some of those tops can be very tough to remove.
PostPosted: Mon Feb 18, 2019 12:00 am
Lol. I literally just calculated the weights and just realized that. Thanks. Could you tell me what plating are on those copper heat sinks, and what those might go as I'm curious.
PostPosted: Mon Feb 18, 2019 6:30 am
Generally if I he base is copper it’s a nickel plate.
And will sell as copper #1
That said many of these caps are solid tungsten.
Obviously as tungsten.
