It is currently Sat Nov 07, 2026 12:43 pm
 Post subject: Assistance Requested
PostPosted: Tue Apr 22, 2014 4:12 pm
Hello! I'd like some help identifying some items. Thank you for the help in advance.
More detailed photographs can be taken. Just ask!
 Post subject: Re: Assistance Requested
PostPosted: Tue Apr 22, 2014 8:09 pm
All those appear to be cable ends. Look at them carefully for gold pins. Any that you can spot gold on you can sell to boardsort.
PostPosted: Wed Apr 23, 2014 4:25 pm
Can I mix them in with my gold cable ends?
Also, will Boardsort take IC chips that come from low-grade circuit boards?
PostPosted: Wed Apr 23, 2014 9:02 pm
are some brass or stainless? Those are not bought ?
PostPosted: Thu Apr 24, 2014 10:30 pm
yes, boardsort will take IC chips harvested from any board you have. Remember to check that what you are removing are chips and not a piece of tin-plated copper that is often confused for an IC chip.
PostPosted: Sat Apr 26, 2014 1:36 pm
Yes, an IC chip is likely going to have at least 6 legs (there are rare exceptions) but they can come from low grade board with no problems.
As far as those ends are concerned, it is impossible to tell from the pictures if they have gold tips or not. They do not look like the millions of ends I have purchased in the past so I would be skeptical that they are gold, but then again, I see new things every day.
