It is currently Fri Sep 25, 2026 3:37 am
 Post subject: Gold connector?
PostPosted: Tue May 21, 2019 5:44 pm
These are different pick ups from hard drives, can the go in gold connector class? If so, how much do I need to clean off them? I.E. Remove black plastic from back of the larger ones pictured!
 Post subject: Re: Gold connector?
PostPosted: Wed May 22, 2019 12:05 am
On the separated ones, you can toss them in peripheral or pull the pins out for a gold pin quote
On the larger pile, trim off the wire (mixed wire) and then the boxes go as midgrade UNLESS they have gold pins which would shift them to peripheral.
