It is currently Wed Nov 04, 2026 11:29 pm
PostPosted: Thu May 16, 2019 7:14 pm
Getting ready to send in some stuff and have a few items to verify before I box up.
First up is an odd Pentium4 CPU/board from a Toshiba laptop. What pile should I toss this in with?
Next is a chip pulled and another one similar still installed on a Sun board. Should I pull the chips (one is pulled already) and what will the board be classed as?
Hoarder turned scrapper.
PostPosted: Fri May 17, 2019 12:59 am
Green/brown fibre with metal
Double gold cap
Same
Kai I believe has a cap, for ibm/via gold cap
Pull the socketed ICs. Any ceramics with gold legs fall into cpu classes. Rest are standard ICs.
It’s a large socket motherboard
PostPosted: Fri May 17, 2019 7:58 pm
Double gold cap
Same
The one I picture above wasn't socketed, but was easy enough to pull with a heat gun. I might pull the second one that's still on the board.
PostPosted: Fri May 17, 2019 8:35 pm
As long as it has pins it’s worth it. Without pins it’s pinless and not worth removing the weight
PostPosted: Sun May 26, 2019 9:00 pm
So, the LSI chip is graded as what?
PostPosted: Sun May 26, 2019 10:51 pm
With pins and a cap ibm/via gold cap
Without cap pentium Mac ceramic
Without pins pinless
