It is currently Mon Nov 02, 2026 8:56 am
PostPosted: Tue Jul 02, 2019 8:43 pm
I'm know the Sims have there own hidden category but would it be fine to throw the few in say connector ends? Same with the gold connectors on the far left side? Now what would the gold pins with plastic be? At last the gold connectors on the right could those go with gold plated pins or would they need a assay and therefore a custom quote? I'm about to send in a shipment and I would like to clear these out. Thanks.
The greatest threat to our planet is the belief that someone else will save it.
PostPosted: Wed Jul 03, 2019 7:20 am
Awesome thanks for the clarification.
PostPosted: Wed Jul 03, 2019 2:01 pm
Left clean gold fingers
Not so left SIM cards
Not so right gold pin connectors (I’d snip the pins loose for gold pins)
Right gold plate (likely) or brass. Use a magnet. If they stick they’re probably gold plate. If not they’re probably brass. Either way boardsort buys them. Plate still gets quotes out, and there’s a brass rate as well.
When you send them in make SURE to have it sorted out and include a notation in the box; and by email with your order number, that there’s gold plated components to test.
