It is currently Sat Aug 29, 2026 10:58 pm
PostPosted: Mon Oct 21, 2019 3:20 pm
The small board with the ribbon cable with the gold pads is from an all-in-1 injet printer. Should I pull the ribbon off? There are gold colored contacts on all of these.
PostPosted: Mon Oct 21, 2019 4:01 pm
1) peripheral
2) peripheral
3) gold pin connector
4) gold pin connector
5) low grade. Remove wire
If you trim down the wire careful to the contacts you can toss the gold contact section in with clean gold fingers
