It is currently Sat Oct 31, 2026 12:41 am
 Post subject: Still more help needed
PostPosted: Fri Nov 15, 2019 6:02 pm
Let's see if I get any right.
I'd say Both Peripheral - Left-almost low telco but too many resistors & capacitors
High Telco
High Telco
Low Telco - due to junk on one side
Low Telco - High Telco if sockets were filled?
PostPosted: Fri Nov 15, 2019 7:40 pm
Low telco/peripheral
High telco
low telco
Low telco
Low telco (no)
Last board the benchmarq box may have a battery in it. I can’t be sure from the photo but I’d suggest yanking it off to keep everyone safe.
PostPosted: Sat Nov 16, 2019 12:14 am
Third from top image 640, coverage seems good. Is it low due to metal on connectors? Thanks!
PostPosted: Sat Nov 16, 2019 1:54 am
Exactly. And keep in mind removing the ports does not automatically guarantee an upgrade in class. It still would be the same (either way there exists the possibility for an upgrade on reception and inspection). I try to usually grade on the lower end of possibility.
Better a surprise upgrade than downgrade.
