It is currently Sat Nov 07, 2026 12:36 pm
 Post subject: Peripherals?
PostPosted: Sun Apr 27, 2014 2:40 pm
Wondering if all of these can be added to peripherals.
Smaller boards in first two photos are green/brown, but have noticeable gold contacts. The areas on the reverse of the larger L-shape board are copper.
The last photo shows both side of two identical boards.
 Post subject: Re: Peripherals?
PostPosted: Mon Apr 28, 2014 1:40 pm
The top row, in order from left to right:
Midgrade, Midgrade, Peripheral, Midgrade, Peripheral.
The boards below the top row can all be Peripheral Grade IF you knock those transformers off.
Even those the large center board is brown on the topside, it has gold pins and an IC or two, so if you take off the transformer it will be Peripheral Grade.
Thanks for the look!
