It is currently Tue Nov 03, 2026 12:10 am
 Post subject: CPU's for grading #1
PostPosted: Wed Dec 11, 2019 5:58 pm
What will this CPU go as? I have one with the cap removed?
Thank you!
 Post subject: Re: CPU's for grading #1
PostPosted: Wed Dec 11, 2019 11:46 pm
With cap green brown fibre with metal
Without the cap green brown fibre without metal
PostPosted: Thu Dec 12, 2019 8:47 am
Thank you!
PostPosted: Fri Dec 20, 2019 3:27 am
Q: most of those caps on CPU are nickel, right?
Besides your gold cap or plated CPU.
PostPosted: Fri Dec 20, 2019 8:47 am
I believe most are copper.
PostPosted: Fri Dec 20, 2019 3:26 pm
Most older caps are copper. Newer ones tend to be aluminium.
A few companies use other metals. AMD is known for their tungsten spreaders.
The plating varies. Gold was very common in the 70s because it was so inexpensive then. Tin is very common today as it works well for shielding as well. Today tin on copper, tin on aluminium, and straight aluminium are most common. AMD still uses tungsten alloys. It’s not worth removing caps EXCEPT
4000 and 25x series intel from the early mid 70s. If you can do so without damaging the tiny fragile thin chips; the gold + cpu rates are slightly higher.
Soviet CPUs. The CCCP had massive gold reserves and utilised them. Same issue as early intel.
AMD k6 series runs from 3-5 and k7. Heavy tungsten rather than alloys. Only if you have a buyer.
PostPosted: Fri Dec 20, 2019 6:52 pm
Thanks mate.
I read up on it and was j.w if there were complete nickel or tungsten ihs's or shields worth removing for upgrade and what not; or just having that pure nickel/ precious metal block to sell alone.
