It is currently Fri Nov 06, 2026 9:27 am
 Post subject: NEC Projector Boards
PostPosted: Sat Feb 08, 2020 12:43 am
I’ve got a few boards from an NEC portable projector I wanted to have double checked on my grading:
1) Peripheral
2) Low Grade
3) Low Grade
4) Mid Grade
5) Mid Grade
4 & 5 don’t have really anything on them so I was leaning towards low grade but because they are green on both sides I thought possibly Mid. Also there is a dark gray heat sink material glued to one of the gold tab green fiber chips on the peripheral board - I was concerned that if I try to pry it off I might pop the chip off the board and down grade it - is it ok to leave that on the chip or should I try to remove it. Thanks for your assistance.
 Post subject: Re: NEC Projector Boards
PostPosted: Sat Feb 08, 2020 2:32 am
Your grades are perfect
PostPosted: Sat Feb 08, 2020 9:29 am
