It is currently Sat Nov 07, 2026 2:15 pm
 Post subject: Last of the re-grading
PostPosted: Wed Feb 12, 2020 9:14 pm
These are all front and back.
PostPosted: Wed Feb 12, 2020 11:59 pm
Apple cpu. I’m debating. It’s a variant of PDS. Just seems like the best option
Peripheral
Left low telco right peripheral.
They both have connectors. One on the left is a zif wire connector and one on the right is a lif ribbon edge. One on the left has higher grade components, and more of them. Plus the higher quality gold pins of the wire connector. I would put that one in low telco.
PostPosted: Thu Feb 13, 2020 8:36 am
Im sorry I may have confused the situations with one having pins and one not.
O and then i realize i have 3 versions of these.
These are separated into 3 pictures front and back. The picture with the side view is the pins I mentioned previously.
Not that this has any bearing on grade, but the possible “Apple cpu”. If i remember right those were came from a mobile security system like on school busses. The HDD was inside a housing, it was channel mounted in the bracket and the boards were mounted to the outside of the bracket with a ribbon wire going from the board to the HDD.
Hope all that makes sense :)
PostPosted: Thu Feb 13, 2020 2:57 pm
Chris said the first board is high telco.
PostPosted: Thu Feb 13, 2020 2:58 pm
Peripheral
Peripheral
Low telco.
The two non-Sony ones are debatable fence sitters.
That pds board is is always an issue. With Apple (and IBM) we just go for Apple Card. And it’s done; as Apple (and IBM) covers 70-something percent of that market.
Anyone else it’s probably going to need to looked at in person. In hand.
I see a reply you just posted saying he said high telco. PDS was invented by Apple and Motorola with IBM. It’s been modified a few dozen times since by other companies’ partnerships. It’s the same premise as a slot processor, with direct bus access, and everything CPU related on a single card. Just using pins instead of contacts. Not that the explanation helps, other than pointing out that minor changes from PDS can raise or lower the value class.
