It is currently Sat Nov 07, 2026 6:01 pm
PostPosted: Sun Mar 01, 2020 12:57 pm
Would these be peripheral and high telco? I wasn't sure about the first picture because it has a lot of extra stuff on it and the second picture has so many chips on it that I thought it might be high telco.
PostPosted: Sun Mar 01, 2020 1:17 pm
The top one is peripheral.
Chris has long said if you rca jacks assume peripheral and ask.
This is textbook for that.
The lower one is interest. That would technically go as a small socket motherboard as it has most of the requirements. Processor or socket. Co-prod or socket. Bridge chips. Ram sockets (in this case ram soldered to the board). Internal and external ports and expansion.
But the population volume will push this further. I’d go high telco here.
Peripheral
High telco
PostPosted: Sun Mar 01, 2020 1:34 pm
Thank you for the quick reply. Both of the boards came out of the same machine. A high end LG TV from around 2005. The second board is the best board I've ever pulled out of a TV.
PostPosted: Sun Mar 01, 2020 3:54 pm
When you look at that you can see how people wind up with ransomware on TVs.
Low end but that’s a full fledged power architecture motherboard.
What tv was it if you don’t mind. Would be an interesting hack project for unix or and old power based MacOS.
PostPosted: Mon Mar 02, 2020 3:27 pm
It came out of an LG 32LX1D TV. The picture below is with the card socket in the lower left hand corner and at the bottom in the middle is a sata port that was connected to a card reader. Thanks again for answering all of my posts. It's very helpful.
PostPosted: Mon Mar 02, 2020 5:21 pm
Thanks.
PostPosted: Mon Mar 02, 2020 6:24 pm
Your welcome.
