It is currently Fri Nov 06, 2026 1:22 am
 Post subject: Loose boards
PostPosted: Thu Mar 12, 2020 7:54 pm
Representin otown, central FL
 Post subject: Re: Loose boards
PostPosted: Thu Mar 12, 2020 10:27 pm
Peripheral, only just barely
Peripheral. Despite the size it’s mostly just space.
PostPosted: Thu Mar 12, 2020 10:54 pm
Shoulda left the connector riser on then, as is 14 oz removed about 6
PostPosted: Thu Mar 12, 2020 11:13 pm
The large one looks like a fairly standard smart tv board. The vast majority of modern A/V electronics main boards will fall into peripheral. Both CPUs are cut down. The primary controller being minimal for the use in driving a TV. The ARM chip for the OS. My database has this board as being from both a DLP TV or a projector with some minor changes in the two uses.
The larger ram chips help keep it afloat. But there’s so little population to space that it simply can’t jump any higher.
The router is as basic and bare as it gets. Without seeing the back side; is there really only the single IC? That’s the most Spartan router/switch I’ve ever seen!
PostPosted: Fri Mar 13, 2020 8:45 pm
Are the black boxes that say tonyo not ic's?
Edit: since idk what it came out of I'm adding this bigun to this thread
Edit² wow my pictures are dogshit, I wonder if Milwaukee makes a digital camera?...
PostPosted: Fri Mar 13, 2020 10:29 pm
They are not
New photo is low telco
cron
