 Post subject: came from laptops.
PostPosted: Mon Jan 25, 2016 11:36 am
Couple of pictures from some laptops.
 Post subject: Re: came from laptops.
PostPosted: Mon Jan 25, 2016 12:17 pm
Thr airport card hadhad its own unlisted class. If it doesn't anymore it will go peripherall.
The aircard shell is 308 stainless (not for board sort)
You have a peripheral card above the aircard shell.
A gold finger ram stick. And a hard drive. Remove and send board to board sort. Rest is "old aluminium" for a local yard.
The motherboard is large socket because it's a laptop board
The cables boardaort buys as mixed wire, or sell locally as copper laminate low.
the cable ends are gold cable ends.
Pic 2 peripheral
Pic 3 green fibre/metal
PostPosted: Mon Jan 25, 2016 3:48 pm
thanks for the quick reply. are laptop boards consider large socket?
PostPosted: Mon Jan 25, 2016 4:33 pm
All laptop boards go large socket except for pre486 which MAY be telco.
PostPosted: Sun Jan 31, 2016 8:04 am
The board above the air card shell is a mousepad from a laptop, if you take the black part of the board and peel it off a lot of times it's all gold plated, I believe it's called an electron board. Not sure how Bruce would buy it, but they're worth saving, good recovery. Just bend a corner of the board, it's real flimsy, this will allow you to peel the black off.
PostPosted: Sun Jan 31, 2016 9:09 am
Those pads go peripheral. I've tried fruitlessly and uselessly many times get a bump, to no avail.
