It is currently Sat Nov 07, 2026 6:43 am
 Post subject: Few more odds n ends
PostPosted: Tue Aug 04, 2020 8:59 pm
Have a few boards to.verify class. Thanks
 Post subject: Re: Few more odds n ends
PostPosted: Tue Aug 04, 2020 9:31 pm
1- gold pin connector end, if those tall pins are gold plated, peripheral
2- gold pin connector end
3- peripheral
4- high telco
5- peripheral
6- Assuming high telco but could go gold finger card because of the transformers and excess weight ratios
PostPosted: Tue Aug 04, 2020 9:58 pm
Shot of pins from #1
PostPosted: Tue Aug 04, 2020 11:01 pm
it can probably sneak into peripheral
PostPosted: Tue Aug 04, 2020 11:58 pm
Number two may get peripheral if there are bare pins on the back but otherwise I will also say that it is gold pin connector.
PostPosted: Fri Aug 07, 2020 8:24 pm
6 is gold finger card
1 is a problem. In the shell it’s usually in its definitely gold pin connector be it a plastic or metal case.
Open? Less weight so peripheral.
