It is currently Sun Aug 30, 2026 11:07 am
 Post subject: AMD Athlon II CPUs
PostPosted: Tue Aug 18, 2020 10:05 am
Trying to classify some AMD Athlon II CPUs and it seems that they are in the no pin CPU category.
http://boardsort.com/cpg15x/thumbnails.php?album=24
Please let me know if this is correct.
Thanks
 Post subject: Re: AMD Athlon II CPUs
PostPosted: Tue Aug 18, 2020 5:38 pm
Here's a pic just in case you need it (it's not an Athlon II, but it's close). The pins are tiny, but there are pins.
PostPosted: Tue Aug 18, 2020 5:51 pm
They should go in the Green Fiber with Metal category.
PostPosted: Wed Aug 19, 2020 12:04 pm
Ok, I was confused with the P4/Green fiber wih metal. I guess the / means P4 or Green . . .
Thanks!
PostPosted: Thu Aug 20, 2020 11:56 pm
As long as the CPU has gold pins and metal top, it will go as green fiber with metal.
Pinless with metal top goes as, no pin CPU
PostPosted: Mon Aug 24, 2020 12:23 am
It is.
Green fibre with metal
That said if it works there’s a real market for that series. The A2 can be hacked up on the firmware and contains most of the opteron code. Specifically the full am87 FP subset.
They’re popular for entry level crypto mining and transaction completion units.
Most working A2s will fetch $15+. Just don’t use eBay for these. There’s a gargantuan fraud ring that has been covered in tech press. Chinese buyers using exporters buy them and then claim they don’t work.
