It is currently Sun Aug 30, 2026 1:44 pm
PostPosted: Thu Sep 03, 2020 6:27 pm
Just checking to see if these are GFC. They are a little different from the normal.
PostPosted: Thu Sep 03, 2020 11:33 pm
Looks like it to me.
Remove the steel brackets for the best rate from boardsort.
If the ICs population were better you might have something that could go to high telco but I don't think there's enough there to make it.
PostPosted: Fri Sep 04, 2020 12:09 am
A little perk tip of the day,
Most instances, leave the metal bracket on GFC cards. Adds to the weight. Removing will actually lose you cost. Just make sure to pull your heat spreaders and fans.
GFC cards able for upgrade to low/high telco , the bracket will be removed along with other components.
PostPosted: Fri Sep 04, 2020 9:32 pm
Hehe! Three generations of video! ;)
Yes gfc
