It is currently Tue Nov 03, 2026 6:14 pm
 Post subject: Help with id please
PostPosted: Sun Oct 04, 2020 6:51 pm
There are 2 parts to A that were connected from a 2000 apple computer. I think this is motherboard but not sure. Keep 2 pieces connected or separate. Thank you for your help
 Post subject: Re: Help with id please
PostPosted: Sun Oct 04, 2020 7:18 pm
A: the smaller board is an Apple CPU and should be sold separately; the big board is a large socket motherboard.
B: Clean Gold Finger Card and heat sink; you might need to remove that paste that's on it to get the Clean Aluminum Heat sink rate though.
C: Hard Drive Board
D: Probably midgrade but maybe peripheral
E: I'm not sure what it came out of, so it could be a CD Rom board or a Hard Drive Board
F: You would need to remove the casing and post a picture of it separately. The board inside might get peripheral or low telecom.
G: I think you need to cut out the gold plated part which i think is bought at a custom rate.
H: Peripheral
I: Peripheral; almost all floppy drive boards are bought as peripheral.
PostPosted: Sun Oct 04, 2020 7:20 pm
Lostinlodos should be around to correct me.
PostPosted: Mon Oct 05, 2020 12:35 pm
B: make sure you remove the ceramic top to the flat pack, on the bottom of the heatsink, and tape it back on the chip top.
You can be devalued if not. Sometimes it's difficult to remove the heat sinks and this happens, try to twist them side to side first before trying to pry up; or break the tension with a small flat head/little objects that would go between.
PostPosted: Mon Oct 05, 2020 1:40 pm
D peripheral
E cd/dvd
F Pop it open for a telco of finger card class. As is peripheral
G cut the smart chip loose. Goes as SIM card
