It is currently Thu Nov 05, 2026 7:16 am
 Post subject: I'd help and questions
PostPosted: Tue Oct 13, 2020 3:14 pm
Help with board i.d. and #6 & 7 came from boards that have value midgrate or less. Is that ok and how do I sort them. Thank you..
PostPosted: Thu Oct 15, 2020 3:36 am
1 backplane
2 both peripheral, separate them
3 peripheral
4 peripheral
5 peripheral
6 peripheral
7 looks like a junk cut from a board. Low grade.
7 normally I suggest standard consumers don’t ship low and mid grade boards.
But if that’s the only one (or your under a pound or so total) it doesn’t hurt to send it in.
PostPosted: Thu Oct 15, 2020 6:36 pm
6 is a phone plug in gold pins. Was wondering if it could go with connectors.
PostPosted: Thu Oct 15, 2020 11:29 pm
6 looks very different when you click on the picture instead of just zooming the page! ;)
Peripheral. At the minimum. Snip the board from the pins relatively cleanly and the pins will go as pin rate.
PostPosted: Thu Oct 15, 2020 11:31 pm
I believe o may have skipped 6 and marked 7 as 6
