It is currently Thu Nov 05, 2026 7:55 pm
PostPosted: Sun Oct 18, 2020 1:29 pm
I have a couple of these large boards that are clearly wire-wrap one one side, and on the other side are many connectors loaded up with gold pins. Would this whole thing go as wire wrap, or would I have to remove all of the gold-pin connectors on the other side? Or, could the whole thing go as pin board? (photos 1 and 2). Wires will be trimmed short, but not unwrapped.
I also have a number that don't have the wire wrap pins on one side. Would these go as backplane? (photos 3 and 4)
The plastic brackets look to be removable on some, and I assume the pins stay put. Do I need to remove those?
Thanks!
PostPosted: Sun Oct 18, 2020 9:50 pm
Remove the bulk of the loose wire and it’s good as is. Wire wrapped pin board.
