It is currently Sun Nov 08, 2026 3:43 am
 Post subject: IC chips? Grading help.
PostPosted: Wed Nov 11, 2020 6:27 pm
Before I waste too much time collecting these I just want to make sure that I am doing this right. the connections on them don't have to be intact correct? I'm using pliers/chizzle to take them out whatever seems to be easiest. Just want to make sure that what I am removing is considered IC chip. Thank you
PostPosted: Wed Nov 11, 2020 7:19 pm
Looks correct so far.
I use a box cutter or heat gun. ;) depending on my intent.
Don’t cut anything off with 4 or fewer pins
or any SIP (single row single line pins) components no matter how many pins. They won’t get IC rate.
PostPosted: Wed Nov 11, 2020 7:47 pm
Thank you
