It is currently Sun Nov 08, 2026 3:43 am
 Post subject: Question
PostPosted: Sun Nov 15, 2020 11:35 pm
I wonder if I remove the gold finger the boards could be down graded ?
 Post subject: Re: Question
PostPosted: Mon Nov 16, 2020 12:43 am
Answer
As is
Will be
No
peripheral
Peripheral
Yes
High telco
Low telco
Yes
High telco
Low telco
PostPosted: Mon Nov 16, 2020 1:01 am
Thanks Lost.
The first board had a slot processor in it. Does it still get graded as peripheral or large socket mobo?
PostPosted: Mon Nov 16, 2020 3:19 am
Yes. It’s not a slot socket (unless my ageing eyes and memory fail me). It’s an esa socket.
Even if it was though it wouldn’t make a motherboard rate as none of the internal expansion, nor any controllers for it, are on the board.
This is a server/workstation class board. All of which bend rules for grading.
Given the pure volume of workstation boards I’ve sent to boardsort over the years I’m confident on this one.
PostPosted: Mon Nov 16, 2020 3:25 am
I don’t doubt you. But the simple issue here is it’s missing both the internal expansion AND the controller for it. Meaning 1/3 the motherboard requirements is missing.
You can tell by the large empty square of contacts.
Both Intel and Via made ESA slot processors. AMD made a Socket A to ESA adaptor.
The processor board itself is sought after by collectors. so ebay may be a good choice for you. $20-$25 for DOA ESA slot processors are not uncommon.
PostPosted: Mon Nov 16, 2020 7:54 am
Thanks a lot Lost.
I took it out of computer from a smog check shop.
