It is currently Sat Nov 07, 2026 5:32 am
 Post subject: Help with grading boards
PostPosted: Sun Jan 03, 2021 11:40 pm
Doing my best to learn what's what with boards. Until now I stashed them all in the same tub. Any help would be greatly appreciated!
Large socket motherboard?
High-grade telco?
Ram, ribbon wire (I will cut off the gold connectors), not sure about the rest.
Another angle:
Thanks!
PostPosted: Mon Jan 04, 2021 1:47 am
Here's my guess:
First Picture: Both Peripheral
Second Picture: All Peripheral
Third Picture: The ribbon wire will go as Mixed Wire and the connectors can be cut off and will go as Connector Ends. The cable on top of the ribbon wire will go as Mixed Wire, too, but the connectors won't get the Connector Ends grade. You can just leave them on. That is because they do not have gold plated pins inside. Only connectors that have gold plated pins or contacts inside get the Connector Ends grade. For the rest of the boards, see the attached picture.
I have drawn a letter on each board that represents a grade.
P: Peripheral
B: Backplane
G: Gold Fingered Ram
Note: These are just guesses. Lostinlodos is the moderator and will correct my grading.
PostPosted: Mon Jan 04, 2021 2:05 am
Thanks!!
Do you know the difference between peripheral and high-grade telcom for future reference?
PostPosted: Mon Jan 04, 2021 11:37 am
There is a huge difference between Peripheral and High Grade Telecom. To get High Grade Telecom, the board has to (usually) have chips over most of the surface area and not much else. Peripheral is very hard for me to explain since there is so many types. My best advice is to read other topics until you get a general idea of how boards are graded. Any boards that you're still not sure on, just post in the forum. But I'm not an expert so if you want an in depth explanation, Lostinlodos would be the one to give it.
Below are some examples of High Grade Telecom.
PostPosted: Mon Jan 04, 2021 11:55 am
Here are some topics that have lots of examples of Peripheral boards:
viewtopic.php?f=4&t=20307
viewtopic.php?f=4&t=20318
viewtopic.php?f=4&t=20317
viewtopic.php?f=4&t=20321
viewtopic.php?f=4&t=20322
viewtopic.php?f=4&t=20308
viewtopic.php?f=4&t=20290
viewtopic.php?f=4&t=20282
viewtopic.php?f=4&t=20331
viewtopic.php?f=4&t=20338
viewtopic.php?f=4&t=20313
viewtopic.php?f=4&t=20358
viewtopic.php?f=4&t=20357
viewtopic.php?f=4&t=20352
viewtopic.php?f=4&t=20360
viewtopic.php?f=4&t=20351
viewtopic.php?f=4&t=20348
viewtopic.php?f=4&t=20350
viewtopic.php?f=4&t=20342
viewtopic.php?f=4&t=20248
PostPosted: Mon Jan 04, 2021 12:41 pm
Here is another topic with some examples of telecom boards.
viewtopic.php?f=4&t=20266
PostPosted: Mon Jan 11, 2021 10:54 pm
First pair is peripheral
triplets. low telco
looks good.
Still crazy in love with that workstation.
