It is currently Sat Nov 07, 2026 1:12 am
 Post subject: What are these called
PostPosted: Fri Jan 15, 2021 11:10 pm
Im new at escraping so i could use some help please. What are these graded at and is there anything i would need to take off before i send it in.?
PostPosted: Sat Jan 16, 2021 8:41 am
High Grade Telecom my guess
PostPosted: Sat Jan 16, 2021 6:38 pm
low telco. gently remove the canister in the centre between the CN8 tooth socket (above) and the Toshiba 68K chip (below). sure, it may be just a capacitor: but this board requires a battery for the memory, and I don't see it anywhere else. So that my best guess as to where it is if you didn't remove it already.
midgrade (I've dealt with these specifically)
peripheral, barely, remove wires.
barely barely barely peripheral. you should remove the transformers, but, uh, no one is gonna do that. that's an OLD serial relay board.
cut all wires free on all boards you send in
