It is currently Fri Oct 30, 2026 4:35 pm
PostPosted: Thu Feb 04, 2021 9:21 pm
I'm still learning from reading some of the identification posts. But here are some that I have that I am not sure about.
PostPosted: Sun Feb 07, 2021 2:00 am
Bump
PostPosted: Fri Feb 12, 2021 11:37 pm
Here's my guess:
First Group: Both High Grade Peripheral
Second Group: Two smallest ones High Grade Peripheral; Two bigger ones Low Grade Peripheral
Third Group: Clean Gold Finger Card
PostPosted: Sat Feb 13, 2021 8:51 pm
they vary, all over the place:
bigger one low telco
smaller one high peripheral
remote low peripheral
cut/snip the plastic off the bigger memory card: all three high peripheral.
clean gold finger card. Put a ceramic cpu back in you loose money but it would be slot processor. put a green fibre CPU in you may make money. Socket 370 was a long era socket and supported ceramics and fibre CPUs. most of the Ceramics were 3rd party gold cap ceramics like the VIA C3 or the WinCX.
PostPosted: Sun Feb 14, 2021 8:22 pm
Thanks. I'm trying to familiarize with the different grading for boards that aren't obvious.
I know that telecom mostly means boards with a lot of IC chips. However, what made the Raspberry Pi qualify as low telecom? Is it because it has tantalum capacitors and a lot of connectors with gold pins?
Can I send in the connectors I snipped off as connector ends? And relating to this, can I send in junk cable connectors and jacks that don't contain gold plated pins?
As for the CPU adapter card, there was a black fiber CPU in it, so I will keep it separate.
PostPosted: Sun Feb 14, 2021 10:17 pm
Value commodities vs less valuable and relationship to board weight.
That one is a full 5 layer board with an inner gold layer and full outer gold layers. So there’s a good jump there alone.
A full size SD card slot with low profile housing. Small steel shells on ports. Gold pin quantity. R-pi and other nano computer boards will generally range from low peripheral up to low telco.
Some junk “for kids” ones fall into midgrade because of weight from being ruggedised. Some really high end ones will make it to high telco like the VC AVS if put together to full spec.
PostPosted: Mon Feb 15, 2021 10:53 am
No, boardsort does not want non gold pin connectors. I have asked and they said no.
Here is a topic on what to do with them in the general discussion forum:
viewtopic.php?f=3&t=18855
