It is currently Mon Nov 02, 2026 8:06 am
 Post subject: Boards o
PostPosted: Sat Feb 06, 2021 1:52 pm
Thank you
 Post subject: Re: Boards o
PostPosted: Sat Feb 06, 2021 5:54 pm
Sorry but do you just post all your boards and let others do the work of grading the boards? I look at what you post and can grade most of them without needed to ask. To make sorting your boards, I would spend some time reading other post in the forms and learn from them. Then like me, only post the ones I question.
Sorry but the rant. I know I will be posting a lot of boards to be verified but I hope I don't waste others time by posting any boards that are clearly in one class or another.
PostPosted: Sat Feb 06, 2021 9:25 pm
I really do appreciate the help in identifying these things. It was an unplanned venture when some semi trailers were purchased with these inside. And to be honest I wanted to make sure I get everything in the right category for when I send them in or drop them off whichever it ends up. This is also a solo venture so I've learned how to dismantle a lot of things.
PostPosted: Sun Feb 07, 2021 7:06 am
The first 2 are low grade. Other 2 I believe are multi socket server. Like people have said, at least the first two are obvious. Look at the pictures of price list and read old posts. It really is easy to get 80-90% of boards on your own once you’ve put the time in.
PostPosted: Sun Feb 07, 2021 10:50 am
I also see that the bottom 2 boards each have a black fiber gold capped chip that is not socketed, so gold capped chip board maybe?
PostPosted: Sat Feb 13, 2021 6:28 pm
low grade
midgrade (thick heavy pins, likely nickel)
gold cap chip board
gold cap chip board.
second one, is a bit of a question. the wire ends are attached to the pin ports. I can't tell if someone yanked the board out intentionally or if they just got flustered when they couldn't get it disconnected. Either way you /should/ be able to remove the pressure tension socket from the port.
push downward on the j30, pull up gently under the centre of the white socket as you pull away from the board. repeat the method for J31
It's literally a coupler socket.
there's a SLIGHT slight chance the pins are gold plated. which would push this to low peripheral.
