It is currently Sat Nov 07, 2026 3:46 pm
 Post subject: directv reciever board
PostPosted: Sun Feb 07, 2016 6:37 pm
what grade ?
and what things can come off and will not hurt the value
PostPosted: Sun Feb 07, 2016 10:05 pm
Depends on the manufacturer but the vast majority are peripheral
PostPosted: Sun Feb 07, 2016 10:20 pm
lostinlodos
Thank you
on they board what can be remove without hurting value like metal , copper and transfomers
PostPosted: Mon Feb 08, 2016 12:09 am
Copper transformers and resistors abe about it. Generally heatsniks, transforms and coppor (square/cube) resistors.
Leave everything else alone.
PostPosted: Mon Feb 08, 2016 6:48 pm
thank you I'll Try to get pic of some of the boards soon see if I did it right
PostPosted: Mon Feb 08, 2016 10:45 pm
pic
PostPosted: Mon Feb 08, 2016 10:58 pm
Here is some of the pic of the directv boards
PostPosted: Tue Feb 09, 2016 12:34 am
They're all peripheral. You can pull the small transformers without hurting value, but not sure why'd want too as the trans is worth less than the peripheral rate.
PostPosted: Tue Feb 09, 2016 6:33 pm
Thank you For your time lostinlodos
